-   -   Ice Maker Overfilling (http://www.diychatroom.com/f47/ice-maker-overfilling-168375/)
J. V. 01-06-2013 11:16 AM
3 Attachment(s)
I have an Amana refrigerator with top freezer and ice maker (IC6).
The water fill cycle is to long and allows water to go into the harvest bin.
I cannot locate the adjustment screw for cube size/water fill time.
I am not certain this model has a adjustment screw? I have the front cover off, but see nothing marked +/-.
Any suggestions appreciated.............John V.
joecaption 01-06-2013 02:26 PM
http://www.acmehowto.com/howto/appli...agicemaker.php
fa_f3_20 01-06-2013 09:47 PM
That little plastic pin on the side is the adjustment screw. However, typically it does not have a lot of range. When I had that happen before, the problem was with the water valve -- it was getting hung open, and it took 10-15 seconds to close after the solenoid de-energized. You might want to observe a cycle, listen for the hum from the solenoid, and note whether the water stops when the hum does, or keeps running.
hardwareman 01-07-2013 07:57 AM
the white screw on the side is the adjustment, turn clockwise to decrease. Max range is 1 full turn before damaging unit.
rkentzel 01-10-2013 11:56 PM
That screw is for adjusting the size of the cube and thats all. If its over flowing there is another reason for it. Most likley water valve make sure its repalced with the one for that model. Model determines how many cc's of water for your particular i/m.
