Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-03-2012, 04:02 PM   #1
Ice maker not working
I have a kenmore elite fridge and the ice maker doesn't work. I recently replaced the filter and now the water works byt there is ni water getting to the I've maker. I can hear it working, that found out makes when it's suppose to be dunking the ice out but no ice. Anyone have any idea what could be wrong with it
woodenSpoon is offline   Reply With Quote
Old 10-03-2012, 06:22 PM   #2
There will be fellows posting that know more than me, but it sounds like the solenoid is no good. Probably you have a set of solenoids, one for water to the water dispenser, one for water to the icemaker. Likely replaced as a set of solenoids. Google "appliance parts" or "refridgerator parts" and you will plenty of places for replacements. Likely you can find them in-town also.
SPS-1 is offline   Reply With Quote
Old 10-03-2012, 08:35 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
could be water valve bad, could be frozen fill tube
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-06-2012, 11:44 AM   #4
JOATMON
ddawg16's Avatar
Make sure the arm is down.....
Are you sure you don't have an on/off switch? Ours does....it's on the side of the unit.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 10-06-2012, 08:52 PM   #5
Everything is in the on position and the lever is down. I can here the market working and cycling there is just no ice, which I assume has to do with the water line or solenoid
Old 10-09-2012, 07:46 AM   #6
custom user
Yep, no water, no ice. Have you checked to see if the solenoid is getting 120 volts? On the Whirlpool you can pop the cover off the ice maker and jump the V to L to bypass the timer.
JasperST is offline   Reply With Quote
Old 10-09-2012, 10:33 AM   #7
See if the water fill tube is clogged with an ice plug, mine did that and had to have the water pump replaced. Frigidaire for me.
I did the old hair dryer thaw to it a few times but it would just freeze up again... had to bite the bullet and call out a technician.
John in NC is offline   Reply With Quote
Old 10-09-2012, 10:50 AM   #8
custom user
Water pump? It is different then. The Whirlpools we have work on water pressure, the valve opens at water flows up to the ice maker. I would have just unplugged it for a day or two to thaw if it was that bad. Your defrost system may not be up to snuff.
Old 10-09-2012, 07:00 PM   #9
#1 HAWKEYE FAN
some call them water pumps but yes they are indeed a solenoid. Often times the solenoid will stick open just a tiny bit and allow water to drip through the valve, and the tube freezes. Thawing the tube is just a temporary fix. The water valve needs to be replaced when this happens.
Old 10-10-2012, 05:58 AM   #10
custom user
Originally Posted by pandoraseom View Post
If the LED is blinking (while the ice maker is on) - the ice maker has to be replaced. If it's not blinking and stays on, then the problem most likely is outside the ice maker.
That's good to know. What about a new circuit board? Is it worth it to do? They list about half price of the maker from our supplier.
LG Ice Maker Not Working Dock Sitter Appliances 1 07-11-2012 09:05 AM
whirlpool ice maker not working. jasondunlap Appliances 1 06-01-2012 08:41 PM
Ice maker not working CarolJean Appliances 3 04-21-2011 09:12 AM
ice maker not working grover352 Appliances 1 04-18-2011 08:07 AM
help!!! Amana ice maker not working jerfran Appliances 2 07-13-2008 04:40 PM
