Ice Maker Not Getting Enough Water During Cycle - Appliances - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 09:28 AM   #1
ice maker not getting enough water during cycle
My ice maker recently started making hollow ice. Then it quit making ice at all.
Here are some things I tried:
* I replaced the filter. No ice.
*Pulled the arm up & cut it off. Several hours later I put the arm down and it made one batch of ice.
*I have melted the clog that was in the pipe, unplugged the unit for one minute and added water to the tray(per whirlpool tech)
*also did a varity of tests with a jump wire. The ice maker will cycle through only the water will not fill up. When I installed the jump wire to test, water ran through fine.
Any suggestions?
twinglesin2001 is offline   Reply With Quote
Old 06-23-2011, 11:51 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
Smile
Any suggestions?
like what? there is only 1 test you can perform with a jumper wire. the only thing you should be using a jumper on is t&h, otherwise you could damage the module.
that being said, hollow cubes are caused by too little water entering the mold. I usually find this problem when the icemaker is hooked up with a self piercing shut off valve.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
twinglesin2001 (06-27-2011)
Old 06-23-2011, 12:28 PM   #3
Too Short? Cut it Again!
There is probably a little tiny piece of particulate or something somewhere you are just not able to see. Or air is somehow trapped in the line. No chance of a hidden kink right? See if you can bleed the lines or replace them I guess. As hinted, you might replace that self-tapping valve but if it all was working before? Unless it got corroded it should still be working.
The Following User Says Thank You to user1007 For This Useful Post:
Old 06-27-2011, 09:14 PM   #4
The test I performed with the jump wire was ...
If there is no ice in the mold take that jumper wire and place one end in the hole marked V and the other end in the hole marked L just long enough to see if water enters the icemaker then remove it. This should power up the water valve and water should enter the icemaker.
I did this and the water did come in quite fast.
If when you do this water does enter the icemaker take that jumper wire and place one end in the hole marked T and the other in the hole marked H for about 15 seconds. When you do this, the icemaker should go through the cycle, the feeler arm should lift up and the water should enter the icemaker.
The ice maker went through all of the steps, except the water never came.
I tried ajusting the water level by turning the adjuster 1/4 inch. Sometimes water is in the tray ( I have watched but never see or hear it run in) and there are small cunes ion the bottom but they never dump. The icemaker will make a batch of ice perfectly about twice a day.
How do I know if my ice maker has a self piercing shut off valve? How would I check it to see if this is the problem?
Thanks for your help!
Old 06-27-2011, 09:21 PM   #5
I have taken the blow dryer several times and heated the tube where the water comes in and the tray itself incase something was blocking it. I am not sure about the kink. I don't know where the water line runs to check it. How would I bleed the lines? The water in the door comes out fine. I don't know how the self-tapping valve could have corroded. Do you know where it is located so I can examine it? Thank you for your help! I feel like it is somethign simple.
Old 06-28-2011, 06:37 AM   #6
If water at door is good, that means your supply and filter are ok. if you get water by V-L means valve ok. if makes cubes sporadiclly and frz temps are ok=bad i/m.
Jacques is offline   Reply With Quote
Old 07-01-2011, 01:23 PM   #7
where are these jumper wire holes marked t, l, v , h? I can't find them.
rileypark is offline   Reply With Quote
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
HELP - No Water to Ice Maker noice Appliances 13 07-17-2007 09:41 AM
