Ice Maker Makes 1 Cube At A Time??? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 12:46 PM   #1
Ice maker makes 1 cube at a time???
OK so many years ago my son rotated the control module manually and broke the ice maker. I know I could have just replaced the control unit but I opted to replace the whole ice maker. Did that tonight and it now makes 1 ice cube at a time... it appears that my water in the door is slower than I remember but I could be wrong. I am guessing my next step is the dual water valve.... am I correct? I purchased the valve just in case but really was too tired to replace it this evening... my other guess is that I didn't level the ice maker and it is only filling the last ice cube in the back. So what do you think? Oh.. voltages appear to be correct on heater, motor, but couldn't catch it at the moment the water was filling.
Mary1 is offline   Reply With Quote
Old 05-19-2011, 01:10 PM   #2
I recently had a problem like this, only half of my tray would fill. The ice maker would open the solinoid valve for the timed 5 seconds, but not enough water came out to fill the tray.
My problem turned out to be the water supply. Since my home did not have a dedicated faucet behind the fridge, I used the kit where you strap a valve to a water line that pierces and seals. I have hard water, and over time deposits built up, and maybe a bit of dirt in the water, who knows, but it was blocking the small hole in the pipe. Anyway, I fully opened and closed the valve a few times and it cleared out the small hole, no problems now.
Oh, I did this AFTER taking apart the solinoids etc, wish I had checked it first.
FixitDragon is offline   Reply With Quote
Old 05-19-2011, 03:28 PM   #3
Household Handyman
Rewards Points: 1,408
You just solved your own problem "Mary1". The water flowed just fine when the old ice-maker worked, right? So, after exchanging the ice maker only, you now have a problem with only one cube in the ice tray filling up during the timed (probably 5 seconds) cycle and the water coming out of the door is slower. Right? "Years ago my son rotated the control module and broke the ice maker". How long did this unit sit with NO water running through the tubing to the ice maker? These tubes will develop "stuff" in them from sitting over time with the old water left in them from the previously working ice maker thus slowing the water flow down. OR: Check the tubing coming into the ice maker unit on the inside of the refrigerator to make sure it is not bent out of shape any, at all, none. OR: Check this same tubing to assure that there is not a plug of ice built up within it just as it enters the fridge. This happens often if the water valve leaks just a bit, as a water valve which is not used for some time will do.
Old 05-19-2011, 03:40 PM   #4
Wow that is funny because we couldn't shut off the tap to put in the valve last night.. it was stuck. ok, so how would I go about putting a new one in and or removing the old one?
Old 05-19-2011, 03:48 PM   #5
Thurman... it sat for at least 8 yrs like that and after a few years nobody really used the water dispenser either. I was a poor single mom for many years and couldn't afford to fix. Now I am playing catch up on all these repairs. I am thinking the problem whether internal or external has to do with water pressure. Last night when I checked the water dispenser I got about 8 oz tops out of it where it said I should get 13-14 oz in 20 seconds.
Old 05-19-2011, 05:30 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
the first thing you must check is the water shut off at the house water line. Lots of times plumbers and home owners will use those cheap worthless self tapping valves that just pierce a very small hole in the line and they will get plugged with rust and sentiment. Check that first and then move on to the other more costly parts. Does your refrig have its own filter??
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-19-2011, 08:38 PM   #7
Hardwareman... hahaha yes I have the cheap self tap but had to drill in because I have galvanized steel water pipes (old old home)... it turned out to be the dual water valve that I had already picked up but hadn't installed because I couldn't shut off that little tap (had to shut off main). As soon as I installed it, got slamming water pressure on water dispenser and ice tray filled up big time!!!! squee!!! Just waiting on ice now!! You guys rock! Husband will be so happy when he gets home!
The Following User Says Thank You to Mary1 For This Useful Post:
Thurman (05-20-2011)
Old 05-19-2011, 08:53 PM   #8
#1 HAWKEYE FAN
good job!
Sears Drill Press makes flash sclaggett Tools 2 12-28-2010 01:12 PM
Diy'er runs out of time & tools turning to the Pros Learn2Build Painting 5 09-20-2010 12:24 AM
Kenmore ice maker acting strange BJLower Appliances 3 10-24-2008 11:14 PM
Whirlpool Ice Maker Problem Aquin Appliances 5 03-26-2008 12:59 PM
Ice Maker makes Blocks of ice Rick Bruner Appliances 1 08-30-2007 11:26 AM
