Ice Maker Keeps Shutting Off - Appliances - DIY Chatroom Home Improvement Forum
Old 04-11-2011, 12:05 PM   #1
Rewards Points: 18
ice maker keeps shutting off
Last weekend I had to take the back of my freezer out to thaw and flush the drain line which had been leaking into the fridge. Ever since we put it back together the ice maker has not been working. If fills and freezes one tray, then the arm pops up in the off position. If we put it down, it fills up one more tray, then again pops up and turns off.
Any ideas on what we may have done to cause this to happen? Its 4-5 years old and I don't have the model number but it is essentially this one:
http://www.whirlpool.com/catalog/pro...t=96&prod=1771
The ice maker was factory installed, we did not do it ourselves.
Any help would be appreciated.
jeni1072 is offline   Reply With Quote
Old 04-11-2011, 09:48 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
did you pull the icemaker to fix the drain tube problem?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-12-2011, 08:55 AM   #3
Rewards Points: 18
yes we had to pull it out in order to get the back panel in the freezer off.
Old 04-12-2011, 09:25 AM   #4
Don't know if you damaged it or this is just coincidental but there was a bad run of i/m where this would happen-bail arm sticks in up position. it has to do with the lube they used-frz's mech' so it doesn't drop back down...if this is the case you'd have to take it apart,clean it up,relube with low temp grease or repl I/M..
Jacques is offline   Reply With Quote
Old 07-26-2015, 07:37 PM   #5
Fixed: make sure when you plug the ice machine into the socket THAT THE SENSOR BAR IS DOWN, otherwise it will drop ice and turn itself off. Hope I can help someone else out there this discussion if 4 years old I know.
jeremyrnr is offline   Reply With Quote
Kenmore (Whirlpool) refrig ice maker problem lexort Appliances 18 05-07-2016 10:28 AM
Ice Maker Stopped Working bsmith95610 Appliances 9 03-21-2011 11:30 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
