Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-17-2011, 09:15 AM   #1
Ice Maker isn't working
Just replaced the leaking water valve on my Whirlpool fridge. Figured everything was fine but the ice maker isn't working. Any suggestions? Water dispenser is fine but ice maker is not.
Also, as I was pushing my fridge back when the water supply line cracked and sprayed water everywhere. . Instead of having to replace the entire supply line can't I just buy a nut and a plastic ferrule? I would really don't want to spend $30 on the supply line when its just a small piece that ripped.
nsb31875 is offline   Reply With Quote
Old 05-18-2011, 06:06 AM   #2
Sure, you can splice that line. but, if it's plastic you should change to copper. don't know what i/m setup you have, but if you search through posts, H/Wman has helped others with i/m problems. you'll have to see which type refers to yours.
Jacques is offline   Reply With Quote
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Ice Maker Stopped Working bsmith95610 Appliances 9 03-21-2011 11:30 AM
Ice maker stopped working. HomerH209 Appliances 3 11-10-2010 08:54 PM
Ice Maker stopped working Whirlpool ED5FHEXNQ00 Hotlatte Appliances 1 05-14-2009 04:15 PM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 10:27 AM
