Ice Maker Crushed Only - Appliances - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 07:41 PM   #1
Ice maker crushed only
My samsung counter depth side by side has quit giving cubes When set for cubes it gives crushed. Gives crushed when set on crushed and gives water when set for water Where do I start?
deejclow is offline   Reply With Quote
Old 04-25-2011, 09:43 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
take out the ice bucket, empty it and run hot water through it. It may have gotten jammed or just iced up. try that and report back
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-25-2011, 10:36 PM   #3
Thanks. I'll try that next week (the fridge is at my lake cottage)
Old 05-27-2011, 07:23 PM   #4
Thawed/ran warm water thru bucket. Problem persists
Old 05-27-2011, 09:47 PM   #5
Rewards Points: 266
I have a similar problem with my GE. it is a mixed batch of creushed and cubes I get though. According to the manual, they say it is notrmal to get some crushed in the cube seting. Still, I will be looking for a model that can get it right when I go looking again.
Jim F is online now   Reply With Quote
Old 03-12-2012, 10:57 AM   #6
I'd like to resurrect/update this thread. Since last posting the problem has evolved to no response when pushing button at all. No water or ice. Icemaker still making ice. Any thoughts?
Old 03-12-2012, 04:46 PM   #7
Originally your problem was the solenoid that controls the cube setting. Now, your problem is also that the motor took a ****.
jfrotten is offline   Reply With Quote
Old 03-13-2012, 10:41 PM   #8
#1 HAWKEYE FAN
You have two separate problems here, is your maker in the door or in the back of the freezer? Since you are not getting anything I would be looking at the actuator switch first. I'm sure you already checked but is the dispenser lock on??
Old 03-14-2012, 09:56 AM   #9
The ice maker is in the freezer but dispenses thru the door. I have checked and the dispense lock is not on. I guess the next step is to get at the switch and test it with my meter?
Old 03-14-2012, 09:15 PM   #10
#1 HAWKEYE FAN
yeah, ohm the actuator switch first
Ice maker will not switch from cubed to crushed TomDellas Electrical 1 03-25-2011 04:02 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 10:27 AM
