-   -   Ice maker crushed only (http://www.diychatroom.com/f47/ice-maker-crushed-only-102708/)
deejclow 04-25-2011 07:41 PM
My samsung counter depth side by side has quit giving cubes When set for cubes it gives crushed. Gives crushed when set on crushed and gives water when set for water Where do I start?
hardwareman 04-25-2011 09:43 PM
take out the ice bucket, empty it and run hot water through it. It may have gotten jammed or just iced up. try that and report back
deejclow 04-25-2011 10:36 PM
Thanks. I'll try that next week (the fridge is at my lake cottage)
deejclow 05-27-2011 07:23 PM
Thawed/ran warm water thru bucket. Problem persists
Jim F 05-27-2011 09:47 PM
I have a similar problem with my GE. it is a mixed batch of creushed and cubes I get though. According to the manual, they say it is notrmal to get some crushed in the cube seting. Still, I will be looking for a model that can get it right when I go looking again.
deejclow 03-12-2012 10:57 AM
I'd like to resurrect/update this thread. Since last posting the problem has evolved to no response when pushing button at all. No water or ice. Icemaker still making ice. Any thoughts?
jfrotten 03-12-2012 04:46 PM
Originally your problem was the solenoid that controls the cube setting. Now, your problem is also that the motor took a ****.
hardwareman 03-13-2012 10:41 PM
You have two separate problems here, is your maker in the door or in the back of the freezer? Since you are not getting anything I would be looking at the actuator switch first. I'm sure you already checked but is the dispenser lock on??
deejclow 03-14-2012 09:56 AM
The ice maker is in the freezer but dispenses thru the door. I have checked and the dispense lock is not on. I guess the next step is to get at the switch and test it with my meter?
hardwareman 03-14-2012 09:15 PM
yeah, ohm the actuator switch first
