Originally Posted by bobnsal
i have a Kenmore ice maker. I've tested the water sending valve on it and it read that it was good. I bypassed the solenoid on the module and it will put water in the tray but it will not fill on its own. Do I need to replace the whole ice making system or Is there a quick fix?
Can you un plug the ice maker from the freezer ?? If so, try that . plug it back in . It may reset itself. If not . you will just have to trouble shoot .. Is the ice maker motor rotating ??
