Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 02-05-2014, 07:43 PM   #1
Painting Contractor
Rewards Points: 85
Ice maker
My ice maker sometimes leaves big clumps of ice. I can clean it out, and it will be okay for a week or two, then it will happen again. Any ideas what may be causing this?
VAProPainter is offline   Reply With Quote
Old 02-05-2014, 10:51 PM   #2
chitownken's Avatar
Rewards Points: 510
Are the "cubes" stuck together like there is too much water in the tray? Is it the entire tray stuck together, or just part of it? Could be sticky water valve. Could be the refrigerator is not level enough if only the back of the tray gets frozen together.
chitownken is offline   Reply With Quote
Old 02-05-2014, 11:59 PM   #3
Painting Contractor
Rewards Points: 85
It's usually just part of it and usually in the back. Only once did it turn into one giant cluster. I'll check it with a level.
Old 02-06-2014, 12:49 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Mine does the same thing. As soon as you figure it out...let me know too!!!
Annoying as all get up and you have to take it out and shake it or break them loose.
Old 02-06-2014, 06:36 AM   #5
Rewards Points: 12,882
Check the temperature in the freezer.
It needs to be no higher then 0 deg. F.
VAProPainter (02-06-2014)
Old 02-06-2014, 06:51 AM   #6
Rewards Points: 1,294
Ice makers and frost free freezers are not friendly to each other. Frost free freezers go thru a defrost cycle every so often to keep ice from forming on everything. This warm cycle also melts the ice a little and then allows it to re-freeze.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Old 02-08-2014, 09:35 AM   #7
chitownken's Avatar
Rewards Points: 510
What is brand and model of your refrigerator? Some have an adjustment for how much water is let into the tray.
Old 02-08-2014, 09:57 AM   #8
PoleCat's Avatar
Rewards Points: 1,646
Yup, that and making sure it is level is critical. Also check that the water line isn't obstructed with ice or lime build up. If the water sprays out too hard it splashes over board.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Ice Maker Italgrl Appliances 2 02-06-2014 01:17 PM
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 04:20 PM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
