Ice Maker - Appliances - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 09:16 PM   #1
Rewards Points: 55
Ice Maker
Tenant moved out and I found bagged ice in the ice maker of Maytag Mzd2752gr. No word about what was happening (or not happening). Lever was up so I dropped it to see if it would make ice. It did not.
Called a repairman who replaced the water valve. Freezer made ice, then continued to fill and flooded the freezer.
Repairman came back and replaced entire ice maker. Same thing happened.
Repairman said he would replace entire ice maker again in case it was defective.
I reminded the repairman that although the ice maker did not make ice, it also did not leak until he replaced the water valve (which was before he replaced the entire ice maker).
He said that "I just do not understand how an ice maker works".
Any insight or advice?
Italgrl is offline   Reply With Quote
Old 02-05-2014, 10:37 PM   #2
chitownken's Avatar
Rewards Points: 510
Sounds suspiciously like a defective water valve.
chitownken is offline   Reply With Quote
Old 02-06-2014, 01:17 PM   #3
sleepyg's Avatar
If he said that he did not understand how a ice maker works, then you need a new repairman! If he was saying that you did not understand, you still need someone new!
If it keeps filling now and did not before the valve was replaced then it is the valve not the ice maker itself.
I used to have a handle on life.........................................But it broke!
sleepyg is offline   Reply With Quote
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 04:20 PM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
