Ice Dispenser Problem - Appliances - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 11:47 AM   #1
Whirlpool GD5RHAXNT00 ice & water through the door. Pivot for ice dispenser door is broken off on right side. It is part of the main through the door panel which is no longer available as a repair part. Any ideas?
treateos is offline   Reply With Quote
Old 02-22-2010, 03:06 PM   #2
I have "repaired" plastic parts using other pieces of plastic. Drilling holes in these with a drill as needed. Cutting down to size with snips.
Gluing them to where they need to go with super glue or "melting" then to the other plastic piece with a soldering iron. (That really stinks, so do it on a warmer day when you can open all the doors/windows.)
Or drilling holes and using machine screws/nuts/washers to hold the plastic piece in place.
Whatever works!
Just sit and stare at the thing and imagine how you may be able add a piece of plastic. Or maybe cut out a section and add a piece of plastic.
Or maybe add a small hinge?
Some of these things can be impossible. But others, with a bit of creativity, can be made to work again.
Might want to post a picture or two if you can and maybe people would have some ideas?
Billy_Bob is offline   Reply With Quote
Old 02-22-2010, 06:21 PM   #3
Try they might have what you are looking for .
They have prints diagrams prices all kinds of good stuff.
As a matter of fact I put your number in and it looked like that had it.
Good Luck
SULTINI is offline   Reply With Quote
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 12:38 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
