Ice Dispenser Not Working (Drive Mechanism Problem) - Appliances - DIY Chatroom Home Improvement Forum
Old 04-14-2009, 09:20 PM   #1
ice dispenser not working (Drive Mechanism problem)
We bought GE side-by-side refrigerator (GSS23QGTBB) a year ago, and we have just connected the refrigerator to the water line last week. It produces a lot of ice cube in the ice storage drawer, and the water dispenser is working well.
The problem is that no ice will come out from ice dispenser when “cubed ice” or “crushed ice” button is selected. We noticed that the drive mechanism was not working as we could see the gear did not rotate at all.
Any advice?
Aline.Yiu is offline   Reply With Quote
Old 04-15-2009, 12:31 AM   #2
Your refrigerator must be still under warranty so get it checked from the manufacturers. some internal panel must have stopped working. Electrical products are better handled by specialist instead of unprofessional hand tempering it.
Dana
Dana11 is offline   Reply With Quote
Old 04-15-2009, 11:27 AM   #3
First I agree with Dana if it’s under warranty call a repairman!
If not do you hear a noise when you attempt to use the dispenser? If so the auger motor (the motor that turns the auger) may be locked up from sitting for so long. You can fix it by removing the ice bin and turning the auger motor to free it up. To do so use a screwdriver and place in the fork that turns the auger and try to turn it by hand it should turn with little resistance.
Last edited by Scuba_Dave; 09-30-2010 at 11:45 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Frigidaire Ice/Water Dispenser Metmagic2k Appliances 60 04-18-2011 07:44 PM
Vista sp1 won't load. drive won't restore sv9779 PC Repairs & Upgrades 42 01-11-2009 10:36 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
GE Profile Ice Cube Dispenser Problem homebrewer Appliances 1 12-20-2006 10:24 PM
