Ice Cube Odor - Appliances - DIY Chatroom Home Improvement Forum
Old 07-30-2011, 02:21 AM   #1
Rewards Points: 139
Ice Cube Odor
Hello,
I keep a glass full of ice cubes with some water at my bedside. In the middle of the night, when all the cubes are melted, the water does not taste right as if some bacteria is in it. Recently I came down with diarrhea and am thinking the ice cubes are the cause. I have stopped using the ice cubes and the diarrhea is going away.
What can I do to improve the Ice cube taste?
rjordan393 is offline   Reply With Quote
Old 07-30-2011, 09:18 AM   #2
Filter your water
matt1208 is offline   Reply With Quote
Old 07-30-2011, 09:28 AM   #3
Learning by Doing
Leah Frances's Avatar
Originally Posted by rjordan393
Hello,
Diarrhea and the ice cubes have nothing in common unless you are living outside of the first world or use unfiltered and untreated water.
As for taste:
1. Filter your water
2. As soon as your cubes freeze empty them out of their trays (or the ice maker) and seal them up in airtight bags or containers. (Freezers have lots of odors and ice is notorious for adsorbing them.)
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-30-2011, 04:06 PM   #4
Sparky
Rewards Points: 510
possibly time for a new filter in the refrig as well
Techy is offline   Reply With Quote
Old 07-31-2011, 04:52 AM   #5
Rewards Points: 139
Leah,
You may have the answer about ice absorbing odors. I do not get the musty taste from the refridgerators water dispenser even when the water sits untouched for 8 hours.. So I will try two things before adding a filter. I will dump out all cubes and place a box or two of sodium bicarbonate in the freezer.
Old 07-31-2011, 11:12 AM   #6
Learning by Doing
Leah,
Ice is more adsorbent of odors than water. If you are talking about a pitcher in your fridge. Way more surface area in ice is exposed, especially with an ice maker. Also the crystalline structure of ice vs liquid water inherently adsorbs more odors.
Also, if you are talking about water in your dispenser it's not really ever 'in' your fridge.
Odd odor from insulation GARoss Insulation 7 03-11-2014 12:10 AM
XL15i Odor During Heating Cycle jgh28792 HVAC 0 04-29-2011 09:54 AM
oil furnace odor jmix69 HVAC 8 12-01-2010 11:27 AM
Whirlpool dishwasher odor Captflx Appliances 8 06-26-2009 08:40 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
