Ice Building Up In The Bottom Of The Freezer In Layers - Appliances - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 09:51 AM   #1
Ice building up in the bottom of the freezer in layers
I have a TPS24BPDA BS . A while back I had layers of ice building up on the bottom of the freezer. I turned off all water but it still persists. Would this be due to a clogged drain line? It appears to be coming from the right rear back bottom corner.
Any thoughts?
Lyle
lyleogle is offline   Reply With Quote
Old 11-08-2010, 04:55 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
defrost drain either froze over and or plugged
hardwareman is offline   Reply With Quote
Old 11-08-2010, 05:33 PM   #3
That is what I thought just some needed re-assurance. Do you know the easiest way to get to it?
Thanks,
Lyle
Old 11-08-2010, 08:41 PM   #4
#1 HAWKEYE FAN
remove the back cover in the freezer section, probably held in with 2 screws and a couple of tabs, get the wifes hair dryer and melt all the ice. you should be able to see the drain tube opening in the bottom of the drain trough, make sure it is clean and free of ice and gunk or you'll have the same problem in a few weeks.
The Following User Says Thank You to hardwareman For This Useful Post:
lyleogle (11-12-2010)
Old 11-08-2010, 09:06 PM   #5
40+yrs Paint Trades
There's lots of info about this on the net. It's a regular problem with "Frigidaire" models. BTW a turkey baster and hot water helps to defrost the line.
Once you get the plastic off (I had to remove the bottom first, then the back. You will see a sheet metal pan under the coil. This pan freezes up and the water from the auto defroster flows into the freezer or often into the lower refrigerator.
There's a home fix to keep it from freezing again: wrap apiece of snaked 12 ga wire through the pan and up to the defrost coil on each end. The extra heat keeps the pan defrosted.
http://www.fixya.com/support/t150729...e_refrigerator
http://repair2000.com/leak.html
hoz49 is offline   Reply With Quote
The Following User Says Thank You to hoz49 For This Useful Post:
Old 11-12-2010, 07:58 PM   #6
guys thanks for the info for sure. I am getting ready to get into it. Wife is out of town so we will have no disturbances.
Thanks again!
Lyle
Old 11-13-2010, 10:06 AM   #7
it is unclogged but the compressor does not run . any ideas. I am going to disassemble again and check
Old 11-13-2010, 10:34 AM   #8
it eventually fired up. I assume it was in a cycle or figuring out in life where it was. Freezer down to 43 and dropping .
Thanks for everyone's help. Have a good weekend.
Lyle
Old 11-13-2010, 11:27 AM   #9
Rewards Points: 1,548
Originally Posted by lyleogle View Post
it eventually fired up. I assume it was in a cycle or figuring out in life where it was. le
Most self defrosting refrigerators and freezers have a timer activated defrost cycle where the compressor is powered off for perhaps an hour. There may or may not be a screwdriver adjustment to manually advance the timer out of the defrost interval. It is possible for this adjustment to be on the rear so you have to move the fridge out from the wall to do the adjustment.
Tags
tps24bpda bs
getting a building permit after construction is done ChrisJJ General DIY Discussions 22 08-15-2012 08:18 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
Load center vs. bottom fed Panel Board. Ugh. wmldwilly Electrical 8 04-23-2009 07:48 PM
setting posts for pole building 2wheelerbill General DIY Discussions 2 04-12-2009 07:13 PM
International building code and permits rforsha Building & Construction 4 08-28-2006 06:35 PM
