I Think I Killed My Stove! >_> - Appliances - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 11:02 AM   #1
Unhappy
I think i killed my stove! >_>
I have a stove that was bought probably about 5 years ago.
Yesterday i was cleaning the area on top of of it and decided to remove the metal cover for the air extractor that's right above it. I somehow dropped it and it fell behind the stove... The stove was not fully plugged in and when the metal plate fell it made both sides of the plug connect, i heard a loud pop and the timer on my stove went off. I've checked the breakers and they are good.
do you think it's just a fuse on the stove that may have gone out? Is there a fuse between the outlet and the breaker? I want to test the outlet, and i've read that i can use a multimeter, isn't 220v current too dangerous? I have a digital multimeter but i've read to stay away from those, is the analog safer?
Thanks for your time!
dalcacio2007 is offline   Reply With Quote
Old 07-01-2011, 12:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
test the outlet for 220 volts with a multimeter, any multimeter will work . I sure don't know why you would think a digital one is any more dangerous than an analog one. The only danger would be if you didn't know how to use one.
digital timer on stove dead means replacement.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-01-2011, 01:28 PM   #3
since most 220 breakers are joined with a clip you can't turn off one with out turning off the other so if one side had popped you couldn't tell by looking. try turning the breaker for the stove completely off and then turning it back on.
Old 07-02-2011, 01:21 PM   #4
Tizzer's Avatar
Rewards Points: 452
I wouldn't go buy a multi-tester unless you'll use it elsewhere. "If" the outlet somehow went bad, you don't want to change it out.
Tizzer is offline   Reply With Quote
Old 07-02-2011, 04:59 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
As Danny stated, turn the breaker to the off position, then turn it back on. See if that brings the stove to life. Even the trained eye can't see that a breaker has tripped sometimes.
Kyle
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 05:54 PM
Wood burning stove trim not flush against chimney Fortitude Appliances 1 11-11-2010 10:28 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 10:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
