Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-26-2011, 08:25 PM   #1
I can't remove the stove top of my GE spectra XL44
Mlightle is offline   Reply With Quote
Old 06-26-2011, 09:01 PM   #2
does this make sense?
the 2 wires on the sides had to be pushed to the front to release
and there are 2 tabs that you have to press from the front to release
what are you fixing?
Old 06-26-2011, 09:17 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
you'll need to provide a little more info than that. A model number would be good.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-28-2011, 06:09 PM   #4
I have XL44 model# JGBP30WEA3WW
I have tried to lift, pull forward............
I need to see if something is dripping from under there. Keep finding a liquid burning in the oven and don't know where it is coming from......Thanx!
Called GE and you can't remove the top on this oven....need to call service
mediaguy is offline   Reply With Quote
Floor burns in basement ceiling, likely under stove brokenknees Flooring 6 10-21-2009 07:04 PM
leak around stove pipe greenvorlon Roofing 2 10-13-2009 02:38 PM
Hood / Vent Requirements for Gas Stove WaldenL HVAC 1 09-09-2009 04:38 PM
Gas Stove Outlet and Over the Range Microwave theatretch85 Electrical 6 04-24-2009 09:25 AM
