I Bought A 4 Foot Subzero - Appliances - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 05:02 PM   #1
I bought a 4 foot subzero
I bought a 4 foot subzero fridge at a garage sale.
We moved it, and it seems to be working well. It is on its own 20 amp circuit.
My only problem is the fan or something seems to be on all the time.
My other fridges and freezers turn off and then on. They cycle as needed but the subzero is on all the time. Is this normal? I did not receive a manual. Is there some kind of maintenance that needs to be performed other than insuring the pans - vents are clear and clean?
Any suggestion will be helpful.
Thanks in advance
Dave
rocklock is offline   Reply With Quote
Old 11-19-2010, 05:29 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
what fan? Is this a fridge only or a freezer/fridge?
post the model too. That might be helpful depending where this goes.
Old 11-19-2010, 06:20 PM   #3
reply
The model is BI-48S/O - Overlay This is it...
Old 11-19-2010, 06:30 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
what fan? inside freezer compartment or the condenser fan on top with the compressors?
hardwareman is offline   Reply With Quote
Old 11-19-2010, 06:34 PM   #5
nap
You talking to me?
nap's Avatar
for your use:
http://www.subzero.com/BuiltInRefrig...8SRefrigerator
Old 11-19-2010, 07:57 PM   #6
re
The condenser fan on top of the compressor.
Old 11-19-2010, 08:04 PM   #7
nap
You talking to me?
nap's Avatar
which compressor? I though the literature said there was 2 compressors.
Is it just the fan or the compressor as well? If just the fan, (and I admit I am not that knowledgeable about these) I would think it might be a stuck relay or temp sensor. If the comp is running as well, I would think low freon or a severe air leak allowing cold to escape.
Build 10 foot wall with 5 foot 2x4's Gandalf Carpentry 22 12-08-2009 09:50 PM
Concrete driveway cost per sq. foot? Flt_Simulation Building & Construction 1 06-20-2009 06:25 AM
Cost per square foot -- very small addition rubeng Building & Construction 7 12-13-2007 12:41 AM
8 foot ceilings -- tray ceiling? lordlang General DIY Discussions 1 12-29-2006 06:09 PM
backing out of the house i bought this old house Building & Construction 9 11-19-2005 12:56 PM
