Husky 1550psi Pressure Washer Wand Leaking Water - Appliances - DIY Chatroom Home Improvement Forum
Old 07-11-2010, 01:42 PM   #1
New House Newbie
Rewards Points: 95
I borrowed a friends pressure washer and used it to wash the cars. Towards the end, water started shooting out from inside the wand and kept the pump running all the tiem. So I shut it down and took the wand apart. Didn't notice anything broken but there are 2 springs in there, 1 of which I did not see where it came from...I have searched the internet for a Husky gun schematic, but no luck. Can anybody help?
C_J_GO is offline   Reply With Quote
Old 07-11-2010, 01:55 PM   #2
i have an old wand for mine that did that same thing.. not posative if it was husky, almost posative its not, anyway. it did the same thing, although i believe it was from being left outside maybe in the winter (the wand) but it was a barely noticeable tiny fracture in the metal inside the handle, i screwed with that thing with epoxys and all kinds of stuff, your best bet is to go buy a new one, i think around 15-20$ usd, you could pick one up at home depot, or places like that.. then you dont have to wonder where its leaking from, or fixing it, will save some headache, and its a good "thank you" for your friend letting you use the washer
sandal82 is offline   Reply With Quote
Old 09-28-2010, 02:44 PM   #3
Don't know if you still have the handle, but I also had water leaking from the handle and took it apart and the 2 springs fell out. I was able to get it back together but it still leaks a little. I can get some pressure and clean. The larger of the springs goes in the black, plastic tube before the valve. The longer, thinner spring goes at the top of the handle, near the valve, where it allows the handle to pivot back in place. Hope this helps.
dontpbg is offline   Reply With Quote
Has anyone ever used one of those garden hose pressure washer converter wands? jpearson311 Landscaping & Lawn Care 7 07-02-2010 06:05 PM
cleaning sewer lines with pressure washer ponch37300 Plumbing 3 07-06-2009 09:26 PM
Pressure washer advice mntentman Tools 1 09-03-2008 09:36 PM
excell pressure washer help ericsloan Tools 1 06-14-2008 03:39 PM
Pressure Washer Question DIYchick Tools 8 02-05-2008 06:44 PM
