How To Wire For Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 11-13-2008, 01:41 PM   #1
How to wire for microwave
I will be getting an under cabinet microwave soon. I am planning on putting in a new circuit for it since we didn't have one before.
My question is, will there be room directly behind the microwave to plug it in so I don't have cords running around?
I would like to have the outlet right behind the unit if possible.
JoeClark is offline   Reply With Quote
Old 11-13-2008, 01:42 PM   #2
The outlet usually goes in the cabinet above the microwave.
jerryh3 is offline   Reply With Quote
Old 11-13-2008, 01:46 PM   #3
The kitchen is bare right now. I am having someone put the cabinets in next week. Should I just wait to run the outlet until the cabinets are in or would there be any benefit to putting the outlet in the wall?
Old 11-13-2008, 01:53 PM   #4
bradnailer's Avatar
Do the rough in wiring before the cabinets are installed then when the cabinets are hung the installer can cut out for the outlet box. If possible, you might want to also install the outlet box proud of the wall so it will be flush with the inside of the cabinet. Or if you are using an old work box, you can just cut the hole for the box then install the box after the install.
bradnailer is offline   Reply With Quote
Old 11-13-2008, 03:46 PM   #5
What he said.
Old 11-13-2008, 05:09 PM   #6
Thanks for the fast replies!
Old 11-13-2008, 08:28 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
It is easier to just leave a wire hanging out of the wall and cut it into the back of the cabinet later. This way it is perfect.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
