How Todo Wiring Of Garbage Disposer - Appliances - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 10:27 PM   #1
how todo wiring of garbage disposer
how to do wiring of garbage disoser putting regular on/off switch
chetan is offline   Reply With Quote
Old 11-27-2010, 09:38 PM   #2
Rewards Points: 6,652
Who what?
Old 11-27-2010, 10:45 PM   #3
Rewards Points: 494
1. locate a new switch in new or existing box.
2. bring 'hot' black and white wires to this new switch box (breaker off of course) from nearest source.
3. run new wiring (black and white wires) from switch box to disposal, behind wall.
4. remove screw(s) holding electrical connection cap on disposal.
5. strip ends of black and white wires and install on disposal screw posts
6. make connections at switch box: white to white in box with a screw cap. push to rear of box. use electrical tape over cap if you want to. one black (hot feed) to either screw on switch. other black (from disposal) to other screw on switch. a single pole switch has only the 2 screw posts. by throwing the switch you interrupt or complete the circuit over the black wiring.
diyorpay is offline   Reply With Quote
Removing rusty garbage disposer bucksone Plumbing 24 02-11-2017 05:54 PM
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Advice on garbage disposer Thurman General DIY Discussions 2 09-04-2010 11:51 AM
Slow-draining garbage disposer Termite Plumbing 2 10-12-2008 09:40 PM
Garbage Disposer not working bucksone Appliances 3 08-07-2007 05:19 PM
