Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-03-2009, 06:03 PM   #1
Default how to test water level switch?
ok, before I even solved my washer motor cutting out problem, the water level switch started acting up. It started when I tilted the front panel backward and the hose got disconnected from the switch. I then simply plugged it back in, but now the water won't stop. Is there a procedure for putting this super sensitive thingy back on? When the water is filling up, should i expect the hose to have the same water level as the tub? The cabinet is out of the machine from doing the motor earlier, so I can see the water level.
xsltuser is offline   Reply With Quote
More On This Topic
Hi, my name is Nathan McCullough on behalf of Expert Village. In these clips we're going to talk about some of the possible problems with your windshield washer system and some hints and tips to get better performance out of it. In this clip we're going... Read More »
In this clip we're going to show you how to hook up the wand to the hose, and the hose to the pressure washer. There's these one-step snap little clip, little washer. Let me show you that again. The hose fits in there snugly; you release the little... Read More »
Hi I'm Stan DeFreitas, Mr. Green Thumb for another gardening idea. Now if you're talking about using a hose end sprayer, well this is one you might try to think about. Its got different attachments and you can actually kind of change the dial a little... Read More »
Sprint Car Cockpit Anatomy
Sprint Car Cockpit Anatomy by Expert Village
Were going to talk about the cockpit. There's quit a few elements to the cockpit. The number one would be the steering wheel which pops on and off with this lock. This locks the steering wheel when it is up, and unlocks when it is down. It just slips on... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be showing you how to check your windshield washer fluid levels. As you take a look at your engine, your windshield washer reservoir is usually located around the outside of your... Read More »
Low hot water pressure crebive Plumbing 24 11-07-2009 09:55 PM
Hot water recirculation malfunction Dustbowldan Plumbing 0 02-07-2009 11:43 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 11:31 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 08:14 PM
Sump pump pit water level Ralph123 Building & Construction 6 07-24-2008 07:33 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
