How To Test A Run Capacitor? - Appliances - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 05:14 PM   #1
How to test a run capacitor?
I've got a Magic Chef Fridge that just stopped working. These don't have a sevice port, so I can't check refridgerant charge. I susspect the run capacitor. How can I check this short of buying a new one?
Lakin is offline   Reply With Quote
Old 08-21-2012, 08:17 PM   #2
Rewards Points: 83
Capacitance meter or a multimeter w capacitance function. You need to disconnect at least one lead.
You can also quick check by unhooking and checking continuity to ground and across terminals. There should be no continuity.
Makes sure you discharge the cap as well.
Protocol. is offline   Reply With Quote
Old 08-21-2012, 09:23 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
does the compresor run? I doubt the cap is the problem.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-21-2012, 09:45 PM   #4
No commpressor does not run. I could check with a meter, but I don't know the specs. This is not your run of the mill cap like on an electric motor. It has no info printed on it. I have power to the cap but compressor does not runand I didn't want to buy one only to find out the compressor is shot. Thanks!
Old 08-21-2012, 10:44 PM   #5
Missouri Bound's Avatar
That is not correct. Yes, you should discharge it, but a 1K ohmmeter will first register resistance, then swing to infinity. If it doesn't move at all it is bad, not good.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
hardwareman (08-22-2012)
Old 08-22-2012, 08:54 AM   #6
#1 HAWKEYE FAN
did you check the compressor overload and relay. Remember it is a run cap. not a start cap.
Old 08-22-2012, 04:45 PM   #7
Overload test good. The scematic does not show a relay. compressor is probably crap.
Old 08-22-2012, 06:05 PM   #8
#1 HAWKEYE FAN
compressor has to have a relay
Old 08-23-2012, 12:10 PM   #9
The part the parts list calls a run cap is listed as a PTC starter on the schematic. I still don't see a relay on this thing. It's a mini fridge for wine cooling if that matters. I calls for a current draw of 1.2 A.
Old 08-23-2012, 03:03 PM   #10
Post some mfg. info and the help offered will be more accurate.
Old 08-23-2012, 04:20 PM   #11
#1 HAWKEYE FAN
ptc starter relay, that is your start relay
How to replace condensor fan motor? twags HVAC 44 08-27-2015 06:09 PM
capacitor blew again!! frocker HVAC 6 07-24-2012 09:42 PM
how do I test Capacitor ? walt1122 Electrical 16 04-05-2012 07:04 PM
run capacitor blew up caught fire in AC unit. saltshaker30 HVAC 2 07-01-2010 10:08 PM
Condenser motor and Capacitor confusion ryanru HVAC 5 06-26-2010 01:25 PM
