-   -   How to test a run capacitor? (http://www.diychatroom.com/f47/how-test-run-capacitor-154395/)
Lakin 08-21-2012 05:14 PM
I've got a Magic Chef Fridge that just stopped working. These don't have a sevice port, so I can't check refridgerant charge. I susspect the run capacitor. How can I check this short of buying a new one?
Protocol. 08-21-2012 08:17 PM
Capacitance meter or a multimeter w capacitance function. You need to disconnect at least one lead.
You can also quick check by unhooking and checking continuity to ground and across terminals. There should be no continuity.
Makes sure you discharge the cap as well.
hardwareman 08-21-2012 09:23 PM
does the compresor run? I doubt the cap is the problem.
Lakin 08-21-2012 09:45 PM
No commpressor does not run. I could check with a meter, but I don't know the specs. This is not your run of the mill cap like on an electric motor. It has no info printed on it. I have power to the cap but compressor does not runand I didn't want to buy one only to find out the compressor is shot. Thanks!:thumbsup:
Missouri Bound 08-21-2012 10:44 PM
That is not correct. :no: Yes, you should discharge it, but a 1K ohmmeter will first register resistance, then swing to infinity. If it doesn't move at all it is bad, not good.
hardwareman 08-22-2012 08:54 AM
did you check the compressor overload and relay. Remember it is a run cap. not a start cap.
Lakin 08-22-2012 04:45 PM
Overload test good. The scematic does not show a relay. compressor is probably crap.
hardwareman 08-22-2012 06:05 PM
compressor has to have a relay
Lakin 08-23-2012 12:10 PM
The part the parts list calls a run cap is listed as a PTC starter on the schematic. I still don't see a relay on this thing. It's a mini fridge for wine cooling if that matters. I calls for a current draw of 1.2 A.
Missouri Bound 08-23-2012 03:03 PM
:thumbsup:Post some mfg. info and the help offered will be more accurate.
hardwareman 08-23-2012 04:20 PM
ptc starter relay, that is your start relay
