How To Remove Rust From Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 08:07 PM   #1
SandraD's Avatar
How to Remove Rust From Stove
I'm helping with restoring the parsonage at my Church.
I'm currently in the kitchen and it looks like a ton of rust build up in the area underneath the drip pans.
Is there a way to efficiently remove the rust and restore the stove to a decent sight?
SandraD is offline   Reply With Quote
Old 04-10-2012, 08:16 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If possible soak them/it in vinegar.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
SandraD (04-10-2012)
Old 04-10-2012, 08:20 PM   #3
Rewards Points: 14,312
Pictures of how bad they are would sure help.
There's no reason there should even be rust in the pans.
May be time for a new stove or at least some new pans.
There is some hoigh heat paints that can be used but all of them stink when they get hot.
Old 04-10-2012, 08:30 PM   #4
SandraD's Avatar
I'll try to get pictures tomorrow. There's no rust in the drip pans themselves. I've removed the burners and the drip pans. It's an old stove top and I'd like to see it replaced, but our finances don't allow it.
The cooking surface of the stove doesn't lift up for easy cleaning of course. Only access I have to the area underneath is the hole where the drip pan and burner goes.
Old 04-10-2012, 08:33 PM   #5
Anyplace that sells appliances takes perfectly good stoves to the dump or scrap yard every day when someone buys a new one.
Old 04-10-2012, 09:18 PM   #6
Too Short? Cut it Again!
Try Naval Jelly to dissolve the rust. Hardware or paint store should have it for different types of metal. Wear gloves although it is not particularly dangerous. A wire brush might do the trick too.
Then decide if it has corroded the metal to the point you need to replace it or the stove. I also wonder how so much moisture gets under the burners and drip pans. Somebody washing down or steam cleaning the top on a regular basis and forgetting to mop of the water that drips down? Pots boiling over and overflowing the drip pans?
The Following User Says Thank You to user1007 For This Useful Post:
Old 04-10-2012, 10:08 PM   #7
SandraD's Avatar
From the shape of the house, they didn't particularly have the time to keep things maintained. I scraped tons of junk from the area, so I wouldn't doubt that it was a 14 year build up of boiled over dishes. No doubt that the stove was never taken apart and cleaned underneath.
Old 04-11-2012, 03:31 AM   #8
If it has been that neglected I think I would take Joe's advice and see if you can intercept a nice used stove as somebody is upgrading or switching appliances. Even new ones without lots of bells and whistles are not that expensive these days.
If nobody has cleaned it you are probably risking attracting insects and rodents too?
Do you have a Habitat for Humanity ReStore near you? They at least try to check out used appliances and I think cut deals for churches.
SandraD (04-11-2012)
Old 04-11-2012, 05:38 PM   #9
SandraD's Avatar
Thanks for all of the advice and help!
I gave the Naval Jelly and wire brush a whirl today. Had to apply Naval Jelly, brush it, and rinse 4 times but it removed most of the rust. There was a match head size hole in the sheet metal, but when I pointed it out they said it wouldn't be a problem.
I took measurements (hopefully correctly) and am going to check in to what kind of deal I can come up with for them.
Old 04-11-2012, 06:06 PM   #10
Isn't the oven underneath that piece of sheet metal? Does the whole go all the way through. I wouldn't be too casual about it although it will probably not hurt anything.
Old 04-11-2012, 06:20 PM   #11
SandraD's Avatar
The stove and oven are separate pieces. The stove top simply sets into a hole on the counter-top over the cabinets. I'm not comfortable with the condition of it, but I have no control. All I can do is try to find a good deal and offer it to the Church.
Old 04-11-2012, 06:24 PM   #12
That's usually referred to as a cooktop. Just to make it easier for you when you call around. Good luck!
Evstarr is offline   Reply With Quote
The Following User Says Thank You to Evstarr For This Useful Post:
Old 04-11-2012, 06:28 PM   #13
Not sure what would come of it but you might post something in the items wanted section of Craigs List. Hopefully a used appliance dealer will have something and will cut you a deal. And don't forget the obvious? Something in the Sunday church bulletin perhaps?
Old 04-12-2012, 07:40 AM   #14
Put some foil tape or something over hole-spillovers?= run into cabinet.
Jacques is offline   Reply With Quote
Tags
stove rust
Replacing Electric stove w/ gas stove PMV Appliances 3 01-02-2012 02:00 AM
I can't remove the stove top of my GE spectra XL44 Mlightle Appliances 3 11-28-2011 05:09 PM
Remove and close off old stove hood venting Chickylala Kitchen & Bath Remodeling 1 09-09-2011 01:02 PM
I think i killed my stove! >_> dalcacio2007 Appliances 4 07-02-2011 03:59 PM
Building a base for my wood stove Verbose Building & Construction 1 10-11-2009 07:06 PM
