How To Remove Matag Agitator ? - Appliances - DIY Chatroom Home Improvement Forum
Old 09-24-2010, 10:01 AM   #1
Rewards Points: 2,646
How to remove Matag agitator ?
I have a Maytag topload washing machine. I want to pull the big center agitator to check for debris stuck under it. There is a small softener dispenser at the top that pulls out readily, but its not obvious how the main agitator pulls out. My guess is that its simple if you know how, but I don't.
SPS-1 is offline   Reply With Quote
Old 09-24-2010, 01:21 PM   #2
Rewards Points: 484
some if you get at the bottom and pull up even like just reach down with left hand at bottom and than on the other side with right hand on the bottom than pull ? Some yrs ago that is the was they came off . If it hasn't came off for yrs.? it may be hard to get it off . good luck
del schisler is offline   Reply With Quote
Old 09-24-2010, 02:13 PM   #3
fabrk8r
fabrk8r's Avatar
You may have to pop off the top part of the agitator that holds the fabric softener dispenser. There is a bolt under that cap.
Also some older models have a bolt in the side of the agitator that locks it to the shaft.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-24-2010, 02:21 PM   #4
No Hacks Allowed!
What is the washer model number?
The service manual for my Maytag topload washer illustrates removal of the dispenser housing and dispenser cup on top of the agitator first. Then remove a single agitator retaining screw that is under the two dispenser units. The agitator should then be free to lift out of the washer.
Good luck!
NoHax is offline   Reply With Quote
Old 09-24-2010, 03:58 PM   #5
Yep, there it is. A screw down the center.
Remove the screw and the agitator came right out.
Thank you
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Granite kitchen countertops replacing tile/mortar countertops - what to remove? vsheetz Building & Construction 17 06-10-2009 07:32 PM
Remove Joist Bridge?? busy1 Building & Construction 9 09-01-2008 09:56 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
