How Old Is This Thing - MARXEL HEAT AIR - Appliances - DIY Chatroom Home Improvement Forum
Old 06-13-2014, 02:07 PM   #1
Rewards Points: 1,646
How old is this thing - MARXEL HEAT AIR
In one of the bathrooms is this very old heater.
It still works, it's on a 120V 20A circuit. When I flipped it on I can feel heat coming out with a bunch of clicking sounds.
Reading the labels closely I can see:
MARXEL ELECTRIC HEAT AIR
CAT. NO. 241-NA
VOLTS 120
WATTS 1000
CYCLES <- this one is unreadable
MARXEL ELECTRIC PRODUCTS INC.
I looked this up this company is no longer around.
The previous owner had put in new tiles but didn't remove it but tiled around it. I don't know how old this thing is and whether it may explode one day. May be I should disconnect it at the panel? I don't think we need a bathroom heater in Miami anyways not even during the winter.
miamicuse is offline   Reply With Quote
Old 06-13-2014, 02:55 PM   #2
Rewards Points: 6,652
Most likely as old as the house. You can contact Markel about it. http://www.markel-products.com/
BTW. Why did you post to two different forums on this? You are going to get better answers on here, then the other forum. Terrylove.com forums have some old timers on there. Markel has been around for ages. You can find their heaters on eBay from all kind of decades.
Old 06-13-2014, 03:42 PM   #3
MarKel or MarXel?
I thought it was an X but may be wrong. The label is so old not too legible. I will check out markel. Thanks.
I wonder if I should remove it but I don't want to create a messy hole with nothing to put back there, of should I leave it as a museum piece.
Old 06-13-2014, 03:55 PM   #4
DIY staff
Rewards Points: 7,174
I'd just leave it ---better to have a retro heater than a funky tile patch---
Old 06-14-2014, 03:58 PM   #5
I turned it on to test it.
It does heat. But it smells, like it hasn't been on for decades. The coil looking thing behind the cage, is that the heating element?
Old 06-14-2014, 05:13 PM   #6
Yes it is. Keep in mind that wiring insulation is dried out. It can end up causing a fire. They do sell rebuilt units. You may be able to find a newer unit, that fits that size of opening. Contact Markel and they should be able to give you something close to that size of older unit.
Other wise you may be able to find someplace online, that rebuilds them.
Heat Pump Aux. Heat not wired correctly / at all? woodardhsd HVAC 12 02-24-2013 08:26 AM
Heat pump is not running on Heat mode frank06 HVAC 17 03-13-2012 03:34 AM
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 07:06 AM
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
changed thermostat on York Affinity, now no heat? sotwell HVAC 1 03-01-2009 05:34 PM
