Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-19-2013, 07:51 PM   #1
How to handle metric (British) fitting on washing machine inlet?
I have a Whirlpool LHW0050pq washing machine. I'd like to replace the 5-year-old rubber hoses that came with the machine. These hoses are threaded for metric on one end and standard at the other. The manual says that installing new hoses requires a "British to universal hose adapter (part no 3357451)." It seems like I will need an adapter in order to replace my hoses with stainless steel braided. I found the part on ebay for $15. Just curious if there is something I could get at local home center in lieu of ordering online.
tabatt07 is offline   Reply With Quote
Old 02-20-2013, 08:14 AM   #2
You can check, but I suspect the typical big box store isn't going to have an adapter like that. You could check with a local plumbing supply house - even if they don't stock what you need they could get it. Take one of the hoses with you.
The Following User Says Thank You to md2lgyk For This Useful Post:
tabatt07 (02-20-2013)
Old 02-20-2013, 09:08 PM   #3
Thanks. Good to know that I'm not making this more difficult than it needs to be.
Old 02-21-2013, 07:42 AM   #4
You're welcome. A real plumbing supply place might even have stainless braided hoses with the correct connectors. That would make things even easier.
Washing machine drain hose - how high can it pump? sheslostcontrol Plumbing 5 01-30-2012 09:39 AM
Washing machine discharge hose Deck Plumbing 7 01-14-2012 09:15 PM
Strainer in washing machine discharge line? bwendholt Plumbing 7 12-04-2011 07:01 AM
Unusual washing machine drain hose hook-up gnguru Plumbing 8 04-28-2011 09:40 PM
washing machine supply valve leaking tina2435 Plumbing 9 01-24-2009 05:17 PM
