Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-18-2011, 09:22 PM   #1
how far can i move a washing machine from the water feed?
What's up. I opened my mouth and mentioned moving my wife's grandmoms w.m. and dryer to her main living level so she could avoid the steps. Well now I gotta do it I'm an electrician so dryers a cake walk. But I'm no plumber. So my ques. Iscan I just run the rubber flex line up stairs on the feed? And same for the drain? Can't be that easy right? I'm looking at about 25' or so from the water supply. Am I just asking for trouble here, any advise will be considered. The cheaper the better. Thanx mike
AlKapone is offline   Reply With Quote
Old 09-18-2011, 10:34 PM   #2
Tileguy
Bud Cline's Avatar
You run the water supplies from the neighbor's house three blocks away if you want to. The drain is a different thing. The washer needs a standpipe drain adjacent to the wash machine for it to work properly. You better call a plumber in this case. you are wanting it to be way too easy.
The Following User Says Thank You to Bud Cline For This Useful Post:
BigJim (09-20-2011)
Old 09-18-2011, 11:23 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Bud is right, you'll have to run a stand pipe over to the washer for the drain.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-18-2011, 11:39 PM   #4
Yea, you're speaking French to me so I definitely will consult a plumber buddy. Thanx. What about a tray for light spiills under the washer? Do they have something like that at supply houses, box stores or is their a method to build one? Guesstimate on a price if so? Definitely balling on a budget here. I'll be lucky if I get a cold beer out to the deal!
Old 09-18-2011, 11:58 PM   #5
Average Joe/ex-Navy IC3
gregzoll's Avatar
As far as the hose & attached cord will reach, without adding to them.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-19-2011, 08:13 AM   #6
Tileguy
Bud Cline's Avatar
Yes there are trays. Where you going to drain the tray to?
Old 09-19-2011, 07:02 PM   #7
The utility sink just below it in the basement ...
Old 09-19-2011, 10:26 PM   #8
Persona Non Grata
VIPlumber's Avatar
Sheet metal supply house, or shop, will carry the type of tray you're looking for. It'll be a square version of what goes under a hot water tank. I guess that it could be ~$100. I think the hot water tanks ones are $50 around here.
VIPlumber is offline   Reply With Quote
Old 09-19-2011, 10:31 PM   #9
gregzoll's Avatar
A hundred bucks VIP. You can get the trays for under $30, that are made by Lambro. Same company that makes utility sinks. http://www.lowes.com/SearchCatalogDi...51&qvRedirect=
Now, the best solution would be to use Detra & make the whole room into a tray, with a proper drain line to allow the overflow to carry away. With using the Lambro trays, they will need a sensor, that will allow for the water to be shut off, along with power to the washer, if the pump to empty it craps out.
Old 09-19-2011, 11:19 PM   #10
Its a bedroom bro.
Old 09-19-2011, 11:45 PM   #11
gregzoll's Avatar
Not even worth it. And I am not your brother. Personally, a washing machine, dryer, etc belong in a utility room, garage if in a warmer climate, or basement if there is one available. The placement of a washing machine in a living space will not only cause health problems due to the humidity from using, but also the moisture from the machines, will help to spur the growth of mold & mildew.
The Following User Says Thank You to gregzoll For This Useful Post:
Leah Frances (09-22-2011)
Old 09-20-2011, 12:01 AM   #12
Persona Non Grata
VIPlumber's Avatar
Good to know, thanks. Never seen those in the big boxes around here.
Old 09-20-2011, 02:26 AM   #13
Thanks for the heads up, but an elderly woman and the basement steps are more of a health concern then the moisture. She also does not sleep in this room. I'm sure I can figure out a way to dehumidify it if needed. Evidently the drainage system will be my Achilles heel.
Old 09-20-2011, 10:37 PM   #14
Send the wife over to do the laundry...
Problem solved.
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
gregzoll (09-20-2011)
Old 09-21-2011, 01:05 AM   #15
JOATMON
ddawg16's Avatar
Problem solved.
best answer
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Got new Washing machine - now I have water hammering in the pipes. What to do? J187 Plumbing 3 05-02-2008 04:07 PM
Can a newbie move over a washing machine? yummy mummy Plumbing 17 02-15-2007 08:31 AM
