How To Drain The Hot Water Every 60 Days To Get Rid Of The Lime Deposit - Appliances - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 02:32 PM   #1
How to drain the hot water every 60 days to get rid of the lime deposit
I have a gas heater and it is required to drain at least a pail of water from the drain valve once a month to get rid of the deposit. I haven't done it since I moved in the house in 2008. I turned off the gas and opened the drain valve. But the cold water was running out from the drain valve, not the hot water ! strange to me. I am the first time to do this kind of job. Thanks for any suggestions.
Junyuan is offline   Reply With Quote
Old 02-14-2012, 05:55 PM   #2
MarginallyQualified
Rewards Points: 2,464
One of these is bound to help:
The Following User Says Thank You to TarheelTerp For This Useful Post:
Junyuan (02-15-2012)
Old 02-15-2012, 02:39 PM   #3
Too Short? Cut it Again!
Remember heat, including hot water rises. Your system may have safety mechanisms so you do not get hurt flushing the system.
You may need to add chemicals to get rid of the deposits. They are dangerous and even if you get them, you might want to call a pro. Or make sure you have gloves and protective clothing.
Generally you flush any system until the water runs clear or close to it. I have never heard of one that suggested a single bucket could do the trick.
If you have water with heavy mineral deposits, you might want to think of some sort of filtering or conversion device on the front end of your water heater or heat boiler. I used to plow through water heaters every couple of years until I modified things.
Old 03-16-2012, 01:08 PM   #4
Rewards Points: 29
Usually it only takes a few minutes to flush whatever might be in the bottom. When I do mine I just open the drain (after I hooked up the hose), run it, close the drain and roll up hose.
I've replaced the drain valve with a ballcock valve so I get a good full flush, I'm thinking about plumbing the drain to my planter out front because I'm getting tired of rolling in and out the hose.
spinfisher is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Main drain water back ups destroyer427 Plumbing 7 04-07-2009 12:58 PM
