How Do U Unclog A Dishwasher? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 07:56 AM   #1
salor06's Avatar
How do u unclog a dishwasher?
It's brand new. But the water just sits at the bottom of washer. We tried googling but no method worked. Help :/
salor06 is offline   Reply With Quote
Old 07-18-2012, 08:03 AM   #2
DIY staff
Rewards Points: 7,174
A brand and model would be helpful--
Is the drain high looped to the top of the cabinet?
Old 07-18-2012, 05:58 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
A plumber might come in handy
Old 07-18-2012, 09:30 PM   #4
ltd
Rewards Points: 536
try youtube . type in unclogging a dishwasher
ltd is offline   Reply With Quote
Old 07-18-2012, 10:11 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 710
It could also be a problem with the evacuation pump or the electronics. Do you hear it kick in when it should be draining? ... If so, there is probably a blockage or routing problem in your drain rather than the DW itself.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 07-19-2012, 03:48 AM   #6
chrisn's Avatar
Rewards Points: 224
I am still betting on a plumber fixing the problem quicker than you are and fixing it right.
Old 07-19-2012, 07:13 AM   #7
DIY staff
Possible that the OP hooked the drain into a garbage disposer without removing the knock out plug----
Old 07-19-2012, 08:58 AM   #8
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
more info, does it actual wash or is it just sitting there not running at all? Is it self installed or professional done? It is a very good bet that what Mike said is the problem, if the drain line runs into a disposal the plug may not have been removed. See it all the time, even seen professioanls do it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 07-19-2012, 10:29 AM   #9
Rewards Points: 3,130
BINGO! Not that I've ever done that LOL.
The Following User Says Thank You to md2lgyk For This Useful Post:
oh'mike (07-19-2012)
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 01:56 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 07:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
