How Do I Know If My Spacesaver Microwave Oven Is Vented To The Outside? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 11:47 AM   #1
Rewards Points: 94
How do I know if my Spacesaver Microwave Oven is vented to the outside?
I looked for an air duct in the the cabinet above but did not see anything there, is it possible that the duct is located behind the microwave?
GE Spacemaker xl1800
JVM1851BH02
shovad is offline   Reply With Quote
Old 05-07-2013, 12:44 PM   #2
Rewards Points: 317
it's highly unlikely that's it's in the wall between the beams.
if it's on an outside wall, it could be vented straight out...did you
look outside behind the microwave for a vent grill cover?
Two Knots is offline   Reply With Quote
The Following 2 Users Say Thank You to Two Knots For This Useful Post:
Hardway (05-07-2013), shovad (05-07-2013)
Old 05-07-2013, 12:55 PM   #3
Rewards Points: 94
Hi Two Knots,
Thanks for your response. I forgot to mention that I stay in a townhome so I share a common wall with the unit next door. So is it possible for an air duct to be ran between the walls? Also when I turn on the vent fan I can feel the air coming from the vents above my microwave. So do you think chances are that I have recirculated exhaust vent with no connection to outside?
Old 05-07-2013, 02:22 PM   #4
Rewards Points: 131
Originally Posted by shovad View Post
Hi Two Knots,
Your 'wave is vented back into the kitchen.
In order to vent outside, methinks....you need to run the duct up and 90* to the closest exterior wall. If your kitchen has soffits, that's where you'd run the duct to the outside. If it doesn't, then you'll need to get creative.
Chokingdogs is offline   Reply With Quote
The Following User Says Thank You to Chokingdogs For This Useful Post:
shovad (05-07-2013)
Old 05-07-2013, 06:19 PM   #5
Rewards Points: 317
I think so, I turned on my micro and hardly felt any air on top.
Old 05-11-2013, 03:43 PM   #6
Oso954's Avatar
Rewards Points: 1,334
Since you are recirculating, there should be a charcoal filter behind the grill above the door. It should be replaced every 6-12 months.
Don't forget to clean the grease filter on the bottom of the microwave. Recommended once a month or as needed.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
shovad (05-11-2013)
Wall oven microwave combo patrick584 Electrical 6 09-02-2012 10:25 PM
split 220V 3wire between Oven and Microwave Abhi Electrical 2 01-17-2011 08:50 PM
GE Spacemaker® Microwave Oven? kcrossley2 Appliances 0 02-03-2010 01:20 AM
Venting of a microwave oven into attic. BobLink General DIY Discussions 2 09-07-2009 04:20 PM
Above Oven Microwave Oven - Maganatron Burned Out chats72 Electrical 7 12-31-2008 01:19 PM
