How Do I Add Rinse Agent To My Dishwasher? - Appliances - DIY Chatroom Home Improvement Forum
Old 08-27-2011, 02:15 AM   #1
How do I add rinse agent to my dishwasher?
Hello:
My dishwasher isn't rinsing dishes well and I heard that rinse agent might solve the problem. But I don't know how to add rinse agent to the dishwasher. I don't have a manual because I am a renter. I will try to call Sears and see if they can help but in the meatime I would appreciate your help. I've included three photos of the relvants parts for your reference. Thank you.
Here's a photo of the diswashing soap compartment and an adjacent compartment that may be where one adds the rinse agent:
Here is a closer look at the unidentified compartment:
Here's a look at the same without the cap. Note the arrow that one can turn to one of a few numerical settings. I would like to know what that does as well.
Heatwave is offline   Reply With Quote
Old 08-27-2011, 09:05 AM   #2
msaeger's Avatar
Rewards Points: 260
You just dump it in the hole labeled max in your photos. If you have the brand and model you can get the manual online.
If you have hard water that is probably more of an issue than the rinse agent.
msaeger is offline   Reply With Quote
Old 08-27-2011, 09:34 AM   #3
You just pour it on top of the arrow. The clear hole on the right is a sight glass. As you pour in the rinse aid, the sight glass will begin to fill. It won't take much to fill it up. You can turn the arrow from max to min to adjust the amount of rinse aid it dispenses in each cycle. Once the sight glass is no longer full, add more. Buy the smallest bottle you can and it will probably last a month or two.
jfrotten is offline   Reply With Quote
The Following User Says Thank You to jfrotten For This Useful Post:
Heatwave (08-27-2011)
Old 08-27-2011, 01:27 PM   #4
This is the info I was looking for. Thanks.
Old 08-27-2011, 01:30 PM   #5
Can you guys tell from the first picture above, where it has soap dishes labeled 15/25, what kind of diswashing detergent I should use? Right now, I use the powder and set the dishwasher to light wash. I also select heat dry and high temp by pushing their respective buttons.
Old 08-27-2011, 09:12 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
the kind of soap does not matter, if you have light soiled dishes only fill the larger cup if you have heavily soiled dishes use both cups.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-27-2011, 09:22 PM   #7
Just make sure you run the hot water at your kitchen faucet until it comes out hot before running your dishwasher. Otherwise, you will be washing your dishes in mostly cold water and the dish soap will never fully disolve and leave a white film on your dishes.
Dishwasher rinse aid dispenser Joe F Appliances 12 02-01-2012 06:24 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 10:52 PM
Kenmore Dishwasher won't rinse hamlindp Appliances 2 02-03-2010 12:09 PM
Kenmore Dishwasher Rinse Aid Draining Tate71 Plumbing 7 07-30-2008 10:41 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
