How Do Bucketless AC Units Work? - Appliances - DIY Chatroom Home Improvement Forum
Old 05-27-2010, 07:02 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
How do bucketless AC units work?
I just ordered this unit: http://www.royalsovereign.com/products/view/35
This one as well as many others say they are "bucketless" or "self evaporating". How exactly does this work? Does the evaporated water go through the exhaust hose I hope? Or just in the air? Since if it just goes in the air, then it would never really dehumidify the room.
Old 05-27-2010, 08:24 PM   #2
Military Mom of 4
Snav's Avatar
It likely works like a self-evaporating refrigerator.
Water from the unit is collected in the bottom of the unit in a large flat pan. Either using air blowing over the top to encourage evaporation (with a fan) or using heat (which most fridges use) the water that's collected is routinely evaporated away.
Since your unit will not run 24/7 - and therefor will not fill the pan 24/7 - the water will evaporate through the entire day even when your unit is not running.
With excessive use, though, the pan can become too full - but modern-units of all types (ac/fridge/etc) have monitors that will balance out the unit running with the evaporation so you won't have routine overflows.
Or - it will notify you if the reclamation pan becomes too full, requiring you to empty it.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
HVAC duct work radiates 60Hz Mike in Arkansas Electrical 3 01-01-2010 07:29 PM
duct work framing kama Carpentry 4 11-15-2008 12:40 PM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
