How To Connect An US220 Volt - Appliances - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 03:59 PM   #1
how to connect an US220 volt
I'm buying an US 220 volt range oven to take overseas , to Argentina .We have 220 volts power , but wiring its different .How can I connect it ?
gustavo is offline   Reply With Quote
Old 10-08-2011, 05:15 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
You probably can't. A US range is a 120/240 volt device. The 120 is needed for display, timer and clock circuits. Likely the 220 in Argentina is 220 only and will not have 110 available.
Coastal South Carolina
rjniles is offline   Reply With Quote
Can I connect 3 relays to one, 12 volt ac adapter? tibberous Electrical 25 07-27-2011 09:31 PM
Want to change a single 240 volt circuit with only one outlet, to a 120 volt circuit with a standard 120 volt outlet. covenant Electrical 7 11-09-2010 06:07 PM
240 volt circuit and 120 volt circuit to shed fortop Electrical 27 06-26-2010 11:37 AM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-22-2010 11:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
