Hotpoint Freezer Cool Fridge Too Cool - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 02:57 PM   #1
Hotpoint freezer cool fridge too cool
Hotpoint csx22d. Freezer turned all the way up (COLDEST) reads (10-28F) fridge turned all the way down just before shutting off reads (31-32F). NO electrical schematic anywhere on unit so I don't know what to jumper out or measure to rule out any problem. I need freezer to drop in temp. If I adjust the fridge temp control to a colder setting, it will get colder in the freezer but it will also get colder in the fridge ie ( adjusting fridge setting to 3 [1-9] will lower freezer temp to 2F but will also lower fridge temp to 27-28F. Freezer door seals appear to seal well and are in good shape.
Is this problem unique?
Maddyrosedad is offline   Reply With Quote
Old 02-19-2009, 05:38 AM   #2
you need service. pretty soon the refig will be down also. call a local guy he'll be able to fix you up. a lot goes into this;not rocket science but not diy.
Jacques is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
Kenmore fridge not cooling, freezer ok bobvanhalder Appliances 20 10-22-2008 11:36 PM
Kenmore fridge not cooling, freezer ok bobvanhalder HVAC 7 10-22-2008 10:52 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
