Hotpoint Electric Range Surface Coil Sparks - Appliances - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 10:16 AM   #1
My tenant lined her drip trays for the surface burners with aluminum foil and must have shorted something out. Now the 'Surface Units' light stays on all the time and the back right burner has a spark that moves round and round the coil when you turn it on. I don't see any indication that the problem coil has melted at the plug end or that the receptacle has melted. The other 3 burners seem to work fine.
Landlordin DE is offline   Reply With Quote
Old 01-28-2013, 12:44 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I doubt lining the pan with foil caused the problem. You have 2 problems. 1) you need a new element 2) you need a new burner switch
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
electric hot water heater in line with DHW coil from boiler bubbler Plumbing 9 04-09-2012 10:43 AM
Placement of electric range Stn4Cap Remodeling 1 01-29-2012 10:10 PM
Converting electric range to dual-fuel? jmklump Appliances 6 12-28-2011 12:25 PM
Loud vibration of indoor coil in heat mode john-hvac-new HVAC 3 11-03-2009 10:27 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
