Hot Water Heater, What Do You Think? - Appliances - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 11:55 AM   #1
Hot water heater, what do you think?
I took these pics last night. Does that blue/greed crud look like a potential problem? It looks like water seeped out at some point, then crusted over. There is no water coming from it. I just don't want it to burst or anything.
Just so you know the overflow pipe does not go straight across, it does angle down, then into the drain pipe. Just an odd angle I took the picture from.
Thanks for any advice!
Scott Stevens is offline   Reply With Quote
Old 10-14-2010, 12:54 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,582
I wouldn't worry about the relief valve pipe, but the connection to the cold water side looks like it should get some attention
hardwareman is offline   Reply With Quote
Old 10-16-2010, 01:44 PM   #3
HVAC / Plumbing
I would take that line off the relief & see if it's leaking. You don't need the relief leaking . It could cause crud to build up in the relief & possibly keep it fron opening if it had to. If it's leaking you have issues. Bad relief or too much pressure
kenmac is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
