Hot Water Heater Leaking HELP!!! - Appliances - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 12:02 AM   #1
Question
I have a gallon Hotpoint electric hot water heater with a puddle all around the bottom. It seems to be leaking from the access panel where the top element is. What should I do? Do I call a 24 hour service? Wait till tomorrow and call someone I know? Try and and figure it out myself?
Mioline is offline   Reply With Quote
Old 08-26-2008, 04:09 PM   #2
Rewards Points: 530
I hope you called someone today. Hopefully, it is just a gasket at the top element. Prop would have been best to kill the power and water supply to it last night.
Old 08-26-2008, 05:45 PM   #3
Fixing a water heater can be a little dangerous, because you are generally dealing with hot water and hot pipes, so if there is someone available to help you, I would suggest contacting them. As boman47k noted, it would probably be a good idea to turn off the water heater and cut off its water supply, which is often possible without cutting the main water off.
Remember that before you turn it back on, the tank should be filled with water, so if you end up having to drain it, make sure you fill it back up before turning it on.
Last edited by AtlanticWBConst.; 09-17-2008 at 07:47 AM. Reason: SITE RULES VIOLATION: Advertising Link Removed from Signature
Charles is offline   Reply With Quote
water heater leaking econdave Plumbing 21 08-17-2008 09:54 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Pipe nipples on water heater leaking big nate Plumbing 2 08-26-2007 02:02 AM
gas hot water heater leaking or not? handymama Plumbing 3 12-30-2006 07:22 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
