Hot Water Heater Help - Appliances - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 10:53 AM   #1
I have a 10 year old A.O. Smith 66 Gal 1400 Watt dual element electric hot water heater. Water out of the fawcet starts off hot but gets cooler as time passes. I first thought the lower element was bad but I'm not sure. I checked the thermostat settings on both elements. Top is set for 130 and lower is set for 140. I can listen and hear water boiling around each element. I measured the voltage across the element terminals and the top measures 240 VAC but the lower only measures 74 VAC. I was going to check continuity across both elements but figured since I can hear water boiling both should be ok. Any ideas? Thanks!
bruce23 is offline   Reply With Quote
Old 11-28-2009, 12:09 PM   #2
Originally Posted by bruce23 View Post
1400 Watt
Usually the elements are 3kw to 5kw.
Anyway, for continuity, [240^2]/1400w = ~40 ohms and 1400w/240v = ~6A, for each element.
Since current does the heating, it'd be better if you measure current draw with your clamp-on ammeter.
Old 11-30-2009, 09:22 AM   #3
Thanks. I think the elements are 4kw. I don't have a clamp on meter so I guess I'll move on to check continuity.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Water Heater tsmith Plumbing 10 12-01-2008 07:24 PM
