Hot Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 10:22 PM   #1
Hot Water Heater
When it rains it pours. I have just been posting here about sizing and venting for new washer and dryer that I have had to buy and now I have discovered that my gas hot water heater is corroded and leaking. As might be clear from this message, I know little about them, though I have begun to read a bit. The question is which one to buy? My wife and I use very little water so I think that a new hybrid one or even a direct heat one would be lost on me (I also wonder about putting a hybrid one in a basement room where the air is pretty cold; or have I misunderstood the principle of it?). It would take me many years to recoup the cost of the unit itself in the savings, even if they worked well. So I think we should look into a good quality cylander gas heater and it seems to me like the ones with 12 year warranty would suit us best. I would also like a 50 gallon tank, in case the family comes for visits. I looked at Lowes and Home Depot, but could not find any 50 g ones with 12 years.
Does anyone know of a good brand name like this?
Alto is offline   Reply With Quote
Old 12-03-2010, 09:50 PM   #2
Rewards Points: 508
Looks like Rheem has an 8 year warranty that can be extended to 12 years.
http://www.rheem.com/products/tank_w...water_heaters/
diyorpay is offline   Reply With Quote
Old 12-04-2010, 10:44 AM   #3
All the same?
When I went to my Lowes store I found that they did have one; whirlpool.
Are they all about the same or what should one look for and are the brands about the same in quality?
Tags
12 year warranty , 50 gallon , water heater
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
