Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-23-2010, 08:15 PM   #1
hot water heater
I replaced both heating elements in my whirlpool hot water heater, and checked the voltage, but it still won't heat the water at all. What else could be the problem?
leberle is offline   Reply With Quote
Old 11-23-2010, 09:28 PM   #2
Location: Boring, Oregon. (The town is named for Mr & Mrs Boring who originally settled this area.)
hot water heater
My first thought was thermostats but both the upper and lower would have to not be working properly....a rare event. So, did you refill the tank with water by opening a nearby hot water faucet to let the air out? The water won't heat if it isn't in the tank.
Oh, and make sure the heating elements haven't been on before filling the tank. That could cause a serious steam event!!!
Last edited by Estacada John; 11-23-2010 at 09:57 PM. Reason: Worried about possible exploding water heater.
Estacada John is offline   Reply With Quote
Old 11-24-2010, 07:31 AM   #3
hot water heater
so you have proper voltage to elements?? safety isn't tripped?? if you didn't fill tank first the new elements will burn right out-they have to be immersed.
Jacques is offline   Reply With Quote
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
