Hot Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 02-08-2013, 04:42 PM   #1
Hot Water Heater
My (pretty old but still working fine) hot water heater is wrapped in this insulation. The area not covered by the insulation is cool to the touch. I plan to paint the garage, and the insulation will make it hard to clean and paint behind the hot water heater. Is this necessary, or can I get rid of it?
Thanks,
John
Moritasgus is offline   Reply With Quote
Old 02-08-2013, 05:20 PM   #2
Rewards Points: 746
You can get rid of it.
It was added to help increase the efficiency of the water heater. You can replace it when you finish, with new if you like. Just make sure to keep it away from the burner.
AandPDan is offline   Reply With Quote
Old 02-08-2013, 05:47 PM   #3
Rewards Points: 13,300
Might want to check how old that thing is and replace it before it blows out on the bottom.
Old 02-10-2013, 07:55 PM   #4
Rewards Points: 194
It's amazing how some of these older tanks will last forever and some of the newer ones are only good for 5 - 10 years now.
Larryh86GT is offline   Reply With Quote
Old 02-10-2013, 08:16 PM   #5
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Moritasgus View Post
My water heater is wrapped in this insulation.
I plan to paint the garage...
Paint **around** the water heater.
Make a nice neat line if you prefer... but leave it all be.
If (when) the time comes to deal with the WH...
paint the remaining 24SF of wall a contrasting color as part of that task.
Old 02-10-2013, 10:34 PM   #6
Insulation
Thanks to all. So I removed the insulation and the DOM on this thing was 1992. Also, now that I can see the tank there is some type of damage or corrosion on the top. I don't see anything near the bottom. Should I just replace it? I have my contractor coming tomorrow on a separate project and I will also have him take a look.
Hot Water Heater-img_1669.jpg   Hot Water Heater-img_1670.jpg   Hot Water Heater-img_1671.jpg
Old 02-10-2013, 10:39 PM   #7
Rewards Points: 746
At 20 years old, it doesn't owe you anything.
Replace it, for peace of mind. A new one should be more efficient due to better insulation but also no garbage will be at the bottom of the tank impeding heat transfer.
FYI, that flex hose scares me. Older ones were known to corrode and leak. New ones have an outer jacket.
Old 02-12-2013, 12:48 PM   #8
Thank you
Thank you, I agree and I am definitely going to replace it. My contractor said he would also replace the gas flex line as well.
John
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
