Hot Water Heater - Appliances - DIY Chatroom Home Improvement Forum
Old 06-04-2012, 12:53 AM   #1
hot water heater
hot water heater keeps over heating
hottie is offline   Reply With Quote
Old 06-04-2012, 08:11 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
please explain a little more detail if you want help
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-06-2012, 07:24 AM   #3
My guess is that you have a dual electric element heater and the lower thermostat is stuck on... More info needed though...
jfrotten is offline   Reply With Quote
Old 06-06-2012, 05:10 PM   #4
Rewards Points: 83
more info needed.
Could be a buildup of calcium, element could be stuck on. etc.
What tells you that the heater is overheating? How old is the unit? how is it powered? (Gas, Electric?)
Protocol. is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
