Hot Water - Appliances - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 07:32 PM   #1
hot water
how to reset vaspor switch
7623 is offline   Reply With Quote
Old 05-19-2011, 09:56 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,586
ok, I'll bite. Whats a vaspor switch
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-20-2011, 09:33 PM   #3
Household Handyman
Rewards Points: 1,408
Face facts here: Post title: Hot water. Question asked (?): How to reset a vaspor switch?
Not enough info here to even make a comment. What is the problem with the hot water? I also have never heard of a "vaspor" switch, please clarify.
Old 05-20-2011, 09:51 PM   #4
i found this about the vapor switch. i am assuming that is what a vaspor switch is. i type like that sometimes also. too many keys on the keyboard
Certain Rheem water gas water heater models feature electronic controls with a flammable vapor sensor installed on the bottom portion of the water heater unit. This sensor is designed to shut off your water heater system to prevent fires in case flammable vapors are present within the area. If your flammable vapor sensor caused your water heater to shut down, check the area immediately for leaking gas or other flammable products. Common household chemicals such as bleach can also trip the safety system as well as unsuccessful burner ignition attempts.
White Rodgers Intelli-Vent PowerVent Control Equipped Models
1 Turn the water heater's blower switch off and disconnect the power cord for the water heater (refer to your particular model's operation guide for the exact location of the blower switch). Disconnect the Molex connector attached to the bottom of the control pad (the left most connector with five pins).
2 Turn on your multi-meter and set it to read resistance or "ohms". Connect one of the multi-meter's probes to the number two pin and the other probe to the number three pin of the Molex connector (middle black wires). If the reading on your multi-meter reads below 9k or above 45k ohms, the flammable vapor sensor is faulty and in need of replacement; you cannot reset the system until this issue is resolved.
3 Reconnect the Molex connector to the bottom of the control pad, reconnect the water heater's power if and turn the blower switch to the "ON" position. Press both the left and right buttons on the control pad at the same time. Wait for the green light on the control pad to blink and press the following buttons in sequence: Left, Right, Left, Left, Right, Left, Right, Right (you will need to perform these actions within 30 seconds of reconnecting the power cord to the water heater in order to be successful).
Honeywell Gas Control Equipped Models
1 Check around your hot water heater for flammable products and for a natural gas leak. Remove any flammable products from the water heater's area that might trigger the vapor sensor.
2 Call your local fire department and/or gas company immediately if you smell the presence of natural gas. Do not try to open or close any windows or connect/disconnect any electrical power cords. Evacuate the home as soon as possible to avoid injury or possible death.
3 Turn the water heater's gas valve switch to the "OFF" position, wait for a few seconds and then flip the switch to the "ON" position to reset the system. The water heater's gas valve is located near the bottom of the unit and connects to your home's natural gas line. If your water heater does not begin working or another "lock out" condition occurs, have a competent hot water heating specialist diagnose the system and make repairs.
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Well Water snuggles2010 Plumbing 3 04-13-2010 02:36 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
