Hot Tub Water Temperature - Appliances - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 07:34 PM   #1
Can I use my hot tub without heating the water; like a little swim pool in the summer time?
tere is offline   Reply With Quote
Old 06-14-2010, 07:42 PM   #2
Yes, mine stays around 70-90 depending upon outside Temp
My hot tub is now heated by solar, heats been off since April 6th
Topped out at 114 with 2 solar water panels
I moved one panel to another hot (warm) tub - stays around 98-100
Now the hot tub tops out at around 106-108
Old 06-22-2010, 02:32 AM   #3
spa water
Thanks Dave, I'm going to try to just turn the heat down as far as it goes and see if the water will cool down to the ambient temperature. It stays around 70 degrees all summer here so hopefully the water will be nice and cool. My electric bill will go way down too!
Sump pump pit water level --- problem de12 Plumbing 52 01-14-2016 07:46 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
