Horrible Screeching From My Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 05:52 AM   #1
Horrible screeching from my dryer
There is a horrible screeching noise coming from my dryer.
Eventually it goes away.
Could this be as easy as changing a belt?
What kind of info do you need to diagnose?
Will
williamwiens is offline   Reply With Quote
Old 03-09-2011, 05:57 AM   #2
the Musigician
DangerMouse's Avatar
It might be even easier. It could just be some belt dressing sprayed on it will fix it, at least temporarily.
DM
Old 03-09-2011, 06:51 AM   #3
Rewards Points: 530
Sometimes a screeching sound can be the drum rollers or slides. Does sound like a squealing belt?
You sat screeching. Could it be metal against metal? Metal against metal will eventually create hole in the bulkhead.
How old is it?
Could also be an idler that keeps tension on the belt.
Old 03-09-2011, 08:08 AM   #4
Sounds like when a fan belt is going on a car...
The dryer is at least 8 years old.
Old 03-09-2011, 09:30 AM   #5
Rewards Points: 530
Belt dressing might let you know whether it is the belt or something else. If the dressing stops the noise, change the belt. Also check the idler pulley and the glides on the dryer or drum rollers. if it has rollers. Also, check any felt that may be on the tub.
Old 03-09-2011, 09:34 AM   #6
Experienced
Jackofall1's Avatar
Hve you seen the cat lately?
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
williamwiens (03-09-2011)
Old 03-09-2011, 09:59 AM   #7
Rewards Points: 530
Mark
Old 03-09-2011, 01:27 PM   #8
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
model number would help, but probably rear rollers. Dryer belts never screech. Change the rollers as soon as possible as left unattended will do lots more damage.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 03-17-2011, 11:24 PM   #9
I had this happen once and found I had a small nail stuck in a rinse hole.
KTBrewer is offline   Reply With Quote
Electric Dryer not turning on c.abrams Electrical 3 01-09-2011 06:18 PM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Problems with Whirlpool Dryer Hookup! Help! maryrgrimm Appliances 1 04-07-2010 07:42 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Dryer Pony Problem. Hobb3s Electrical 17 09-30-2008 08:16 PM
