Hooking Up A Stove Range, All Wires Are Black How Do Tell Which Is Positive And Negative And Ground? - Appliances - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 08:13 PM   #1
Hooking up a stove range, all wires are black how do tell which is positive and negative and ground?
Hooking up a stove range, all 3 wires are black how do tell which is positive and negative and ground?
darugg is offline   Reply With Quote
Old 09-16-2010, 08:16 PM   #2
HVAC / Plumbing
Use volt meter. Is it 220 volts
kenmac is offline   Reply With Quote
Old 09-16-2010, 10:09 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
there is no positive or negative.
also, where in the world are you located? It makes a big difference.
Old 09-17-2010, 07:05 AM   #4
HVAC / Plumbing
if it's 220v you will have 2 hots 1 ground
Old 09-17-2010, 08:19 AM   #5
Household Handyman
Rewards Points: 1,408
Based on experience: IF all three supply wires are black, then one of them should have another colored stripe, a "tracer" color, on it which would indicate the ground/neutral wire. This would be an older set-up with no dedicated ground. IF there is no wiring with any colored tracer on it, then I would say the wires need to be traced back to the panel, confirmed as to which each wire really is, and properly labeled. In today's world a dedicated ground should be put in at this time. David
