-   -   Hooking up a stove range, all wires are black how do tell which is positive and negative and ground? (http://www.diychatroom.com/f47/hooking-up-stove-range-all-wires-black-how-do-tell-positive-negative-ground-81606/)
darugg 09-16-2010 08:13 PM
Hooking up a stove range, all 3 wires are black how do tell which is positive and negative and ground?
kenmac 09-16-2010 08:16 PM
Use volt meter. Is it 220 volts
nap 09-16-2010 10:09 PM
there is no positive or negative.
also, where in the world are you located? It makes a big difference.
kenmac 09-17-2010 07:05 AM
if it's 220v you will have 2 hots 1 ground
Thurman 09-17-2010 08:19 AM
Based on experience: IF all three supply wires are black, then one of them should have another colored stripe, a "tracer" color, on it which would indicate the ground/neutral wire. This would be an older set-up with no dedicated ground. IF there is no wiring with any colored tracer on it, then I would say the wires need to be traced back to the panel, confirmed as to which each wire really is, and properly labeled. In today's world a dedicated ground should be put in at this time. David
