Hooking Up Dryer To Power Outlet - Appliances - DIY Chatroom Home Improvement Forum
Old 02-16-2015, 02:11 PM   #1
Rewards Points: 2
hooking up dryer to power outlet
I'm wondering if it would be possible to wire a NEMA 10-50 power cord for ranges into a 240 v 30 amp clothes dryer and plugging into a 10-50 receptacle block. Any issues with that? Also, what about a custom built 25 ft. extension cord with Nema 10-50 male on one end and Nema 10-50 female on the other? These are 10 gauge wires. I wouldn't want to burn my house down. Thanks!
inkster is offline   Reply With Quote
Old 02-16-2015, 03:21 PM   #2
Oso954's Avatar
Rewards Points: 2,288
You are not supposed to use a 50 amp receptacle on a 30 amp circuit. Plugging a 30 amp dryer into a 50 amp circuit violates the mfg instructions and increases fire risk should something go wrong.
what about a custom built 25 ft. extension cord with Nema 10-50 ...10 gauge wires ?
Putting 50 amp cord caps on a 30 amp extension cord is an accident looking for a place to happen.
Edit: If those 2 questions are related, running a dryer on an extension cord is not permitted by code.
Oso954 is online now   Reply With Quote
Old 02-16-2015, 04:24 PM   #3
Retired from the grind
gregzoll's Avatar
Rewards Points: 2,940
Just swap out the breaker and outlet.
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Stackable washer dryer power question muphtrician Electrical 27 12-03-2012 07:21 PM
New outlet using power from a nearby switch. surecook Electrical 23 10-16-2009 06:27 PM
Dryer outlet vs. Range outlet cindakay Electrical 24 04-13-2009 06:01 PM
No power in outlet sherben2 Electrical 16 03-19-2009 11:35 AM
Turned off power. Changed outlet. No power to entire house. pauly99 Electrical 39 03-06-2009 05:09 PM
